Westfield_XI
According to the GMS story one can use the stock MC with the MGB calipers. I think the benefit comes from the piston area. They are as heavy as the Sprite parts, but have a larger swept area and use larger pads, or so I have been told. The Toyota calipers are 4 piston with two different diameters to promote even pressure on the pads, I suspect that they are alloy, but will need to get ahold of a pair to be certain. They are running about $50 to $80 w/o a core, with core I have seen them as low as $31 ea.
As far ar brake bias, I used MGB GT wheel cylinders when I rebuilt the rear drums. That too was part of the GMS budget brake upgrade and is supposed to improve rear braking ability. I agree that dual MC's with a biasing bar would be ideal, but have you priced a Tilton pedal box!!!?
