Which Lucas dynamo does a BJ7 have? A C45??
twas_brillig
We've got our car tucked away for the winter, complete with a noisy dynamo. It's not at all accessible for the next few months and I wasn't smart enough to check which model Lucas dynamo I've got. Can anyone (kindly) advise if it was the C45, or some other model, that the BJ7 came with? Thanks, Doug
gonzo
C 45 for AH 3000s including BJ 7's. Consider conversion to an Dynamator alternator which is design to look like our original generator (pic below). I purchased one for my BJ-7 from a Canadian-based distributor. This fun and worthwhile conversion also includes planning: NEGATIVE ground; modifying voltage regulator to a terminal block; running a 10G wire direct to battery lead (at solenoid); possibly switching wires on e-fuel pump and installing original generator pulley onto the Dynamator (I purchased the larger aluminum one from Denis Welch Motorsports). GONZO
gonzo
Understood. DWM's large pulley option is matched to original AH 3000 pulley dimension. The one I installed charges at 14.3V at 900 - 1100 RPM and about the same as the generator it replaced. At idle speeds anywhere between 400 to 700 RPM the Low (field) charge lamp does not glow - idle set at 650 RPM.
In addition to lots of surface area around the Dynamator case, those fins offer quite a bit of air circulation for cooling. I believe the Dynamator has Bosch internals.
T
twas_brillig
I purchased a Dynamator (plus a relay and control box) from Brit Bits in Edmonton Alberta last winter, and forgot all about it until we fished the BJ7 out a few weeks back and I noticed the charge light wasn't going out. Found it, and will start installing tomorrow. fingers crossed! Doug
T
twas_brillig
Gonzo: just ran into your comment on the steering issue that you Dyamator had packed it in. Did you learn why? stay with going back to the generator? Any advice regards the durability of hte dynamator? I think I'll have one driving season worth of warranty on it. Thanks, Doug
angelfj1 C39 Lucas Dynamo rebuild - Moss armature does not fit Triumph 9
ArcticOne GT6 WANTED - LUCAS C40L DYNAMO / GENERATOR [1968 GT6] Triumph 4
MGTF1250Dave Lucas 12V Dynamo / Generator Specifications Triumph 2
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
Michael Oritt Lucas 576 lights Austin Healey 4
J MGC Lucas alternator/regulator MG 3
Rob Glasgow Weird Lucas Headlight Austin Healey 7
CJD General Tech Boeing using Lucas parts? Triumph 7
D Wanted lucas wt618 Triumph Classifieds 0
Basil SOLD!! Lucas Spot and Fog lamps Jaguar Classifieds 1
H Lucas Prince of darkness Austin Healey 4
NutmegCT Lucas 432 bulb Restoration & Tools 6
T Lucas HF 1748 horn parts Austin Healey 5
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
