Which DVOM?
NutmegCT
Bronze
I've decided to replace my (no longer 100% trustworthy) 20 year old RadioShack $9.95 Micronta volt/ohm meter. Geez - $9.95 and it only lasts 20 years? What ever happened to quality? /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
What do you guys use for electronics work?
I do car electrical and home electronics (small radios, components, PCBs, etc.)
I want digital, relatively small, voltage 0-250, AC/DC, resistance with audible signal, amperage, and if possible rpm (on a spinning object - not engine "ignition" rpm). Like putting a white tab on an axle, pointing the meter toward it, and reading the rpm as the axle turns.
Any suggestions?
thanks.
Tom
Wellll... Fluke is the Top name in automotive type DVOMs, but the price shows it. I have a knock-off of a Fluke meter... that I can't remember the name of right now...DOH! But it does RPM (Ignition type through an inductive lead) and has the Temp wire. Auto or manual ranging with min-max and hold feature, works nice, and has held up well. Check out Snap-on and Mac tools ans Flukes online catalogs for an idea of some good ones, then search ebay for good deals.
I got a Sears DVOM with the temp unit. It cost less than $30. Love it. I, also, use mine for electronic work Radios and amps, etc. Look at your local store they have several models and price range.
That is how i find my electrical gremlins....just usually a fluke..
mark
Another vote for Fluke.
i've had a fluke 77 for 20 years now
I'll also add a recommendation for the Fluke. My Fluke 87 has never led me wrong.
