TR2/3/3A Where to place the switch for the windshield washer & bottle
Got_All_4
Never had one of these in my car before. I've seen the switch/pump mounted where the overdrive switch goes and now that I have an overdrive that spot is taken up. So I purchased one of those TUDER bottles and have an electric pump I'm going to mount under the dash somewhere but my biggest dilemma is where to put the switch and bottle. In 1980 I had the dash recovered and on the right bottom side of the gauges the PO had a cigarette lighter installed and that hole is covered up. The other corner is open. So looking for some ideas where to place them.
M_Pied_Lourd
TR3driver
Great Pumpkin - R.I.P
Many cars had it over by the corner of the cubby box. You can see the empty hole in this shot of TS39781LO
P3170011.jpg~original
But it was apparently usually a dealer-installed item, so they might have put it anywhere.
FWIW, here's an updated link to TeriAnn's photo of the same location
https://www.expeditionlandrover.info/2trSite/TR.images/TR washer_pump.jpeg
BobbyO
Bottle on the left side wheel well, forward of the windshield wiper motor. I don't have the bottle or holder but screw holes are there where it was mounted at one time. Friend has the bottle holder but no bottle and that's where it's mounted. Hope this helps.
TR3driver
Ditto
Got_All_4
Got_All_4
I've seen pics where they were mounted next to the battery on the driver side. I guess this is not correct.
TR3driver
Less common, perhaps, but I don't think you should call it "not correct". The kid at the dealer might have put it almost anywhere!
R TR4/4A TR4a, where to place jack Triumph 0
Luke_Healey Where's the best place to have tandem MC resleeved Spridgets 21
M Where to place rear bumper over-riders. Spridgets 3
2wrench Help with where to place one more wire set Triumph 14
TexasSprite Where to place jackstands? Spridgets 6
G Where is the best place to look for a MG Midget? Spridgets 12
tony barnhill So, Where's the Most Unusual Place You've... MG 43
B MGA Where to Buy, What to Buy? Axle Nut MG 9
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
C Where to wire a Pusher fan - BN1 Austin Healey 16
Rob Glasgow Brackets, where do they go? Austin Healey 3
