TR2/3/3A Where on the clutch pedal?
bnw
Actually "drove" my project out of the garage yesterday to clean up and make some new space. It's been so long, I've forgotten where the clutch should disengage / engage. It seems to be fully engaged high on the pedal but there is plenty of pedal free play at the top. I would say the whole process takes place in the last 30% of pedal travel. Does it have anything to do with the slave push rod adjustment? Or, is this normal for an old TR3? The components were "almost" new when installed.
CJD
My "action" is about in the last 30% too. I wouldn't say it has a lot of freeplay though. When I think of "freeplay" I think of pedal moving but the master cylinder piston does not. My piston starts to move almost immediately...at least no more than 1/2". I think you are referring to freeplay as the distance before the clutch starts to release. If you are referring to the latter, then your clutch sounds about normal to me.
TR3driver
Great Pumpkin - R.I.P
Some freeplay is certainly normal, and it can be hard to tell when the slave piston starts to move (which I would include in freeplay). To me, a properly adjusted TR clutch is very similar to more modern hydraulic clutches (eg Miata).
But if you are concerned, it certainly can't hurt to check the adjustments. Freeplay at the MC pushrod is only supposed to be .010" for early cars with the pedal stop, but wear usually makes it much larger without the stop.
Slave freeplay spec is 0.100" on cars with Girling hydraulics.
Added together IIRC that comes to around 3/4" at the pedal, more without the pedal stop.
Geo Hahn
...Added together IIRC that comes to around 3/4" at the pedal, more without the pedal stop.
FWIW, I added the stop bolts for the pedals to be able to fine tune free movement (early cars had them, later ones still have the holes for them):
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
dklawson GT6 GT6 Clutch Failure - Where to Look First Triumph 16
E T-Series 1973 MG Midget, Where to Start with a clutch issue MG 8
H WHERE TO BUY A CLUTCH M/C PUSHROD? Triumph 5
D T-Series Where to buy clutch parts MG 5
W Where is the oil on my clutch disk coming from? Austin Healey 14
jjbunn T-Series Clutch Master Cylinder - where is it?! MG 3
C T-Series Midget clutch slave where? MG 5
S T-Series Where did my clutch fluid go... MG 7
B MGA Where to Buy, What to Buy? Axle Nut MG 8
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
C Where to wire a Pusher fan - BN1 Austin Healey 16
