Where did my horn go??
mk2sprite
Had my '63 Sprite on stands while rebuilding front suspension. Put it down and went in to start it up and see my horn button had popped off, so put it back and no horn. Early steering wheel with center push. Horns worked fine and actually blew them about 4 days ago before starting the job. I have power at the horns and at the horn contact, pencil thing. I do not see any loose parts inside the car but the only way I can get them to sound is if I run a jumper wire from the contact and really dig it into the back side of the metal dash. I can not get them to sound grounding the contact anywhere inside the steering wheel hub. I'm guessing it's the contace/slip ring but wonder what happened, it always worked fine? Horn push is basically new too.
a little puzzled
Mike
Jim_Gruber
You answered your question. You took the front suspension apart. Ground path goes through the steering column. Run a separate ground wire to the steering column and I'll bet you can make it work.
oldguysrule
Are ther any extra parts you want to get rid of? I have a 63 Midget and amlooking for steel wheels and seats for now.
Let me now please,
Jim
warwick-steve Where did the smell go? Austin Healey 11
R Where did it go? A who-done-it mystery! Austin Healey 18
Jim_Newman Where did I go wrong? Austin Healey 37
M where did it go Triumph 2
B TR2/3/3A Where did I see the picture of the TR3 bulkhead Triumph 6
T where did my coolant go? Austin Healey 5
KVH Where Did They All Go? Triumph 5
Stewart So where did you take your B today? MG 6
mgblue79 Where did the summer go? Spridgets 23
jlaird Where oh where did Jaybird go? MG 51
jsneddon TR2/3/3A Where did all my TR3 bottom end power go? Triumph 6
S T-Series Where did my clutch fluid go... MG 7
B MGA Where to Buy, What to Buy? Axle Nut MG 8
1 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 4
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
