Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Looks like you used the Valve cover stud holes to bolt the chains down? Did you actually raise, then lower the car while keeping the chain tight? [/QUOTE]
Kent,
The car was on the ground at that point. We used the crane to pull up on it. At that point, the rope had it broken away from the block, but that one area of the stud just would not budge.
Finally, with the intake completely out of the way, a larger pry bar wedged in, closer to the stud and the lift pulling up, it did slowly come loose.
Kent,
