bigjones
Hi folks,
I went to tighten that castellated nut but 46 ft lbs seems an awful lot.
I tightened it by hand - the disc could be spun with a certain amount of drag that felt about right. (Just to give you an idea of my "hand tight" - I could turn the nut further from hand-tight with the torque wrench set at 10 ft ilbs)
Using the torque wrench, without even reaching 46 ft lbs, the disc could not be spun - it is locked solid.
I realise that the nut should be backed off (if necessary) to get the slot in the spindle lined up with a castellation but even so.
I must be doing something wrong here.
Any ideas?
Adrian
1500 Midget
Any ideas?
Adrian
1500 Midget
