Deleted member 12902
I have found alot of information in the forums about wider tires and wheels that people are using on their Healey but no where does any one mention off set or back spacing. I have a set of steel factory Healey wheels. I wish to make the wheels a bit wider (15x5.5, 15x6) but I want to retain the original centers so I can run the original hubcaps. Everyone talks about Mini-lites and wire wheels but again no one speaks about the off set. I need this info so that when wider rims are welded to my existing centers I will not have rubbing issues on the front inner wheel wells. The rear is easy to figure out since there is no steering to worry about. The car is a 1961-3000 BT7 with stock suspension and I want to keep the tires within the stock fender openings with no tire protrusion.
Is there a different offset from front to back or are they the same?
What is the off set for a 5-1/2" rim and a 6" rim?
Can anyone that has wider wheels help me out?
Thanks,
Pete D
rusty1c
Thanks,
Pete D
rusty1c
