Hello Bryan,
"Any extra oil you take to the head is oil you take away from the bottom end."
That would be true except for the pressure relief valve, as excess pressure is bled off. Volume drop is also a pressure loss so if the pressure remains constant then the relief valve must be controlling the pressure.
Incidentally, I had another look at the engine from Le Taxi, and that has an oil feed to the head.
Alec
Alec
Otherwise, it's really tough to drill that hole around two corners inside the head.
