TR6 What year TR6 did NOT have a differential oil drai
tdskip
I have a 1971 that I'm getting back into drivable condition and I can't seem to find the drain plug.
It may just be an over abundance of dirt and grin combined with an under-abundance of brains.
Thanks!
DougF
The drain plug is at the bottom. Some people like to use the diff. as a jacking point. If you can't find it, it may have been sheared off.
Geo Hahn
Re: What year TR6 did NOT have a differential oil
The drain plug was deleted with the TR4... guess some shiny-pants accountant in Coventry found it would save 5 pence.
Perhaps it was added back later in the TR production... couldn't say. If you have one I would think it would be real obvious.
Simon TR4a
I have 2 diffs for my irs TR4a, both have just the one plug which is up on the side of the diff and used to fill and drain, by vacuum/siphon.
The back covers of my diffs are alloy, so I drilled and tapped a drain plug in the one that's on the car now. (Can't remember whether the diff of my TR6 was the same; I don't remember ever changing the fluid on that car!)
Simon.
G
If you want a drain plug on a TR6 Diff, you will need to drill and tap one, just like TFR did when they rebuilt mine. Otherwise, the only way to "drain" it is to open it up. Suction draining won't remove all the oil and sludge.
Bill
R6MGS
heh, wish I'd known this before I spend an hour underneath the TR last weekend looking for the dang thing....Finally gave up, I've gotta bring the car in to get the 'clunk' checked so I'll have them do the diffy oil too.
DougF
I was wrong. I remembered seeing one on my car (must have been the TR3) and referenced a catalog that showed one. Just looked under the TR6 and it wasn't there.
Kurtis
[ QUOTE ]
[/ QUOTE ]
Geo,
The early TR4s had 'em, didn't they? At mine does.
Geo Hahn
Perhaps they were deleted somewhere along the way. CT36536 does not have a drain.
BTW -- What a bonehead thing to omit. I suppose there could be a situation where that plug would strike something but I think there are plenty of other bits that are likely to bottom out first.
DougF
My rear sway bar mounts act as skid plates, saving my exhaust from scraping which in turn would save the differential.
Kurtis
[ QUOTE ]
[/ QUOTE ]
I agree... It doesn't really make a lot of sense. I'm sure glad I have one, as I've certainly used it. Being able easily drain and replace the differential fluid is a great piece of mind on a 40+ year old car.
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 ‘74 1/2+ TR6 Spotted 0
E TR6 TR6 flip-up bonnet question Triumph 4
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
T TR6 TR6 Tire Pressures Triumph 2
B TR6 Triumph tr6 coolant leak Triumph 4
