What year cut-over to the 1500?
jvandyke
Morris said:
'75.
The year of the clack.
What does that mean?
I had a '75 Midget in '88 or so.
Rik
1975 was the first year of Rubber Bumper Midgets. 74 was still chrome but had those large rubber overiders stuck on the chrome bumpers.
Rik
jvandyke
What is meant by "clack" I'm wondering.
Morris
Clack-clack-clack-clack
Dang! There went my thrust washer.
(yet another extremely poor attempt at humor on my part. My apologies to all)
198686d
Question from relatively new owner of a frame-off restored BE with 1275cc engine (also am old geezer with dangerously limited knowledge of same): Can a 1500cc engine go in a BE?
dave
61 BE
05 Vespa ET4
04 Mini Cooper S with mods
JPSmit
Back away from the 1500 and no one gets hurt :nonono:
Seriously, as the owner of a 1500 I have to acknowledge that the 1275 is the better engine. As I recall, once in the past year a 1500 in a 1275 square body showed up on Ebay and no one could figure out why. So, hypothetically the answer is probably yes but I don't know why you'd want to.
Morris
As a 1500 owner, I will agree with JP whole heartedly.
The worst part is all the A-series guys making cracks at our expense all the time.
It's awful.
JPSmit
I know, we need a support group!
Adult Survivors (of) Serious Harassment Over Lousy Engined Spridgets
(try that acronym you meanies) :cryin: :grouphug:
BugEyeBear
Morris,
You're gonna have to warn us in advance the next time you are trying to be funny. That way we'll all know we should be laughing...
(just ribbing you!) :wink:
"Cheers!" :cheers:
-Bear-
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Rut Cut down windshield Spridgets 22
BN6 BJ8 Outrigger Cut Out For Exhaust Austin Healey 3
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
69MGC MGC Cut out the Rust! MG 9
D cut-off switch Austin Healey 20
W TR2/3/3A Why a PO cut these holes in rear floor? Also, question re dealing with captive nuts Triumph 6
K TR2/3/3A A cut down side curtain for Fall driving? Triumph 7
CJD TR2/3/3A Cut away TR3 Triumph 6
Boink Moss Healey Cut-out... I'll ask... Austin Healey 2
Boink Cut-away B series engine... MG 6
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
BobMunch MGB The MGB Cut-away, Heritage Motor Centre Museum MG 11
J Windshield question pt.2: Why not cut the frame? Spridgets 9
Boink Battery cut-off switch options... or??? Spridgets 10
K TR2/3/3A TR3 Cut Off Side Curtain. Triumph 18
D battery cut off switch Austin Healey 29
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
Tinkerman Battery cut-off switch installation Triumph 22
AUSMHLY fuel cut off Austin Healey 23
vping T-Series Adding a battery cut off switch. MG 16
G To cut or not to cut Austin Healey 3
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
Ouagabambou Cut, torn steering inner tube [+ photograph] Austin Healey 22
T TR6 What year TR6 cut over to Type-J O/D? Triumph 3
roofman Looks like Dale made the cut! Triumph 13
B T-Series cut off switch in MGB? MG 7
jmwuva05 Fuel pump cut off switch Spridgets 6
R Cut off switch wire Austin Healey 2
jlaird First cut on trophies for Lake of the Ozarks Spridgets 32
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
J TR6 Inertia cut out [off] switch TR6 Triumph 9
TR6oldtimer Fuzzy door seals to cut or not, buy new or keep Triumph 12
T What do you guys use to cut floor pan sheet metal? Triumph 7
T Wedge Cut wire on TR8 Ballast Resister Triumph 2
tahoe healey fuel pump cut off switch post Austin Healey 21
T Cut/Splice Spark Plug Wires?? Triumph 13
S Battary cut off switch Austin Healey 1
R6MGS T-Series Late MGB fuel cut off switch MG 5
A dash light cut off switch Austin Healey 9
jlaird Bat, cut off switch Spridgets 7
S TR2/3/3A TR3 Turn Signal Auto Cut-Off Triumph 5
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
G Fuel cut-off valve MG 5
A Battery cut off switch Austin Healey 15
C LCB header with 1500 single carb inlet manifold Spridgets 1
