Rob_Edwards said:My thoughts exactly -- '69 B, all emissions gear intact & functioning, could not ask for it to run better!
Hap Waldrop said:I see alot of the soldered poppet valves.... why not just replace with new solid butterflies, they are $15.00 or less a piece, that's what I do on all my carb rebuilds.
eschneider said:Rob_Edwards said:My thoughts exactly -- '69 B, all emissions gear intact & functioning, could not ask for it to run better!
Am I the only one who peed myself laughing?
PAUL161 said:I have the EGR valves in my HIFs along with the full complement of EGR equipment the car came with in 72, pump, gulp valve and all, and I couldn't ask for it to run any better. Lots of pep, no bucking, jerking and will run 70 MPH all day long and I get great gas mileage. I still can't see why everyone wants to, (strip), the engine of the original equipment when it's going to be used as a street machine. Amazing! Absolutely amazing. Sorry for running on.
DrEntropy said:There's only one reliable supplier left for SU parts AFAIK: Curto. The stuff from the white box suppliers is usually ill-fitting ballast material.
Rob_Edwards said:eschneider said:Rob_Edwards said:My thoughts exactly -- '69 B, all emissions gear intact & functioning, could not ask for it to run better!
Apparently. What, you can't believe that my car runs well? Come drive it!
DrEntropy said:eschneider said:Rob_Edwards said:My thoughts exactly -- '69 B, all emissions gear intact & functioning, could not ask for it to run better!
No, Eric.
But I deleted my response.
Rob_P said:Rob,
I don't think anyone is questioning how well your car runs. The "funny" part about your quote is the '69 B should have little to no emissions gear. (At least compared to the 76 and newer). It's the smog pump (looks like an extra alternator) that most people remove.
For example, my '76 B (for off road purposes only /bcforum/images/%%GRAEMLIN_URL%%/wink.gif ) has been modified to be set up more like your '69 then when it came off the showroom floor.
Although the next time i am in NC, i would love to drive your car!! /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
eschneider said:Joke's on me. I had no idea a '69 had poppets, smog pump, gulp valve......
I'm officially putting my tail between my legs now.
eschneider said:Hap Waldrop said:I see alot of the soldered poppet valves.... why not just replace with new solid butterflies, they are $15.00 or less a piece, that's what I do on all my carb rebuilds.
One answer to "why" is that the old butterflies usually fit when you re-install them.....
Sounds like you haven't had a problem with new ones though - mind if I ask where you get 'em?
