Hi Jim,
For plugs, the NGK BP6ES or Champ. N9YC should work. It seems that everyone has their own favorite.
As far as plug gap, try .030 to .035". The hotter coil will probably fire plug gaps larger than this but the wider the gap the higher voltage requirement & there are limits to the distributor cap & rotor voltage insulation capabilities. Too wide gaps may result in internal arcing in the cap during wet or humid conditions.
