terriphill
Engine in, everything hooked up. Torqued the head down to specs (3 times) Set all the rockers according to spec. Detached the coil wire so it wouldn't fire off immediately. Turned the key. It spun around freely like there was no compression about 5 or 6 turns then quit spinning and all I heard was clicks. Acts like its locked up.
Can't turn the harmonic balancer at all with it out of gear.
We just picked up this motor new rings, turned and balanced the crank, replaced the bearings, balanced rods, new camshaft and lifters.
AAAAAAARGH. Any ideas. Removed the starter, removed the head again. 1 and 4 pistons down, 2 and 3 pistons half way up. Still can't get the harmonic balancer to budge. /bcforum/images/%%GRAEMLIN_URL%%/confused.gif
