TR2/3/3A What color should these parts be?
Got_All_4
Just repaired, sandblasted and primed these. What color should the shackles be and also the front bonnet lift assembly.
Dr_Mike
I had the same question about the bonnet catch. Most photos in
Piggott's books are hard to decipher, but one is clearly black in a red body.But it does not mean it is the original colour!
So either will do but i shall paint mine black, because I like it and it is convenient. And I am not are about a coloured prop for the hood!
carpecursusII
The prop rod should also be body color, it was installed prior to painting, as was the rubber grommet that retains it. I'm attaching pictures of some original cars I've been able to find. TS 5265 and TS 3285
CJD
This is out of the judging guide:
"It is believed that the release mechanism and prop rod, including the early version’s cable, was installed prior to painting of the body shell so that the components were painted body color. Natural or body color is accepted on the release components not part of the body or bonnet (e.g., cable, springs, spring-thimble cup)."
So, natural metal color or painted body color. The most common latch assembly is body color.
You can tell that my TR3A is not correct...I went with black on the spring assembly, but I did use body on the prop rod.
Here is the judging guide on the rear shackles:
"A. The external surfaces of the rear brakes, suspension, and axle assemblies were usually painted black. Early shock absorber bodies may be found in natural metal. Some markings are possible."
Got_All_4 TR2/3/3A What color should this part be? Triumph 5
PatGalvin TR2/3/3A what color should it be...? Triumph 7
T MGA What color should an MGA brake master cylinder be? MG 6
A Paint Color Codes Austin Healey 0
B Cove Paint Color Ideas Austin Healey 10
F TR2/3/3A Headlight bucket color Triumph 22
P General TR What color is original for engine parts? Triumph 7
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
B TR6 Help with color and color code / paint recommendation Triumph 4
S 1958 100/6 Bumper Brackets Color Austin Healey 2
R Cooling Fan Color Austin Healey 6
B TR4/4A Dash Color? Triumph 3
B TR4/4A Gas Tank color? Triumph 4
A Color Matching Austin CU 50 "Dominican Blue" British Motor Corp 3
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
D TR2/3/3A center panel indicator light color Triumph 10
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
R Speedo High Beam Warning Light Color Austin Healey 14
Rut TR4/4A Dash color Triumph 9
G Opinion on spark plug color Austin Healey 15
R TR6 Sapphire Blue color Match? Restoration & Tools 3
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
M Rear ended pumpkin color Austin Healey 6
T TR2/3/3A Chassis paint color Triumph 10
B Dashboard color Austin A40 Devon 1948 Restoration & Tools 2
Marvin Gruber Most popular color for A/H 3000 Austin Healey 56
Johnny AH BJ7 Trafficator Color? Austin Healey 7
N Bumper bracket and fan shroud color Austin Healey 5
P TR2/3/3A TR2 color questions Triumph 23
HealeyRick Color Match Misconception Austin Healey 15
R TR2/3/3A Color Wiring Diagram-1954 TR-2 Triumph 1
I TR6 Gauge/color wire ? Triumph 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
B GT6 Chassis color Triumph 4
D TR6 What Color is This? Triumph 11
T BN7 wiring diagram in color Austin Healey 7
busybrit TR4/4A Steel dashboard color Triumph 1
T Austin Healey 100 engine color Austin Healey 10
Rut Bugeye generator color Spridgets 22
simon1966 100 X Brace Color? Austin Healey 16
F TR2/3/3A Wheel Color Triumph 2
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
J TR6 Paint color Triumph 22
simon1966 Eclipse Day Photos, back to her old color! Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
maxwedge5281 engine compartment color Austin Healey 2
