When the car is running - even idling, there is no fuel coming out the overflow.
Timing was correct - and has not been changed - but I'll check again
carb damper moves fine
choke is off/ disconnected
valve adjustment is correct
wondering about spark - pulled a plug and it is yellow when I thought it should be blue.
has new coil, new rotor, new distributor cap, new plug wires,
The only other thing I can think of is that I pulled the diodes on the red/white wires under the dash for things like the EGR - can't imagine it would be this - and barely want to mention it because of this crowd's short attention span. :wink:
Ideas?
Ideas?
