Well ain't this just peaches and cream.
That is great news!
Which reminds us how we all might be 'dead in the water' and scratching our heads, without the members of British Car Forum.
Tom
Amen! You guys not only saved my butt this time, but were also a huge help when my spitfire gearbox disintegrated on me a few years back. This place is the best!
ummm... errant nut in the bellhousing... I'd be for clutch removal, flywheel too. A REALLY comprehensive visual inspection of all the parts in there to find a stud or bolt end with a missing nut. Transmixer front plate, etc. Now's the time. That nut weren't beamed in.
And another thought, O/T tho...
Be SURE to inspect and better, just replace the diff carrier bearings in th' Ferrutzi. Nasty habit of rusting from sitting exposed to atmosphere (the diff case warms up to temp then when parked for extended periods the condensation in the case does the damage). Upper half of the bearings sit out of the lube.
I did have the Timken numbers around ~someplace~ but no idea where. Just match 'em up at a proper bearing supply house. IIRC the originals were Timken.
Oh, and replace those case studs for the diff "lid" with stainless Allen-head cap screws while the lump is out. You may never need to do it but the carrier can then be accessed with the unit in-situ.
I thought about taking the clutch off, but admit I didn't. I did do a pretty thorough inspection of what I could see, plus I looked at all the parts diagrams and couldn't find anywhere there even should be a nut in there to begin with. The nut must have made it's way in there at some point when somebody had it open before.
Actually already inspected those before the engine came out. One of the seals went and was dumping gear oil into my inner axle shaft boot. Blew it out on the highway and made a nice big cloud of brown smoke! So I rebuild both axle shafts, and inspected those bearings while the shafts were out.
Anyway, I'm having the engine professionally rebuilt (I'm not risking a $20K engine on my rebuilding skills!) and he's got those on his list to double check as well.
:thumbsup:
Somewhere in this pile of 26K+ nonsense posts is a photo of me leanin' over a Ferrari V12 block. Rode herd over a few of 'em prancin' pony cars over the years.
How long have you had the 308?
Not long enough to be rebuilding the engine! I've had it about four years. It was due for a belt change and major service last year. I was going to do it first thing this spring. Now that the postmortem is all done, the trouble turned out to be a <span style="font-style: italic">very</span> worn front timing gear. That and a weak tensioner bearing spring caused the belt to jump and my valves to say hello to my pistons. The guy who did the last major didn't replace the gear when he should have! That'll teach me to put a major off for six months...
You haven't seen any blind squirrels lingering around your garage lately have you?! :wink:
I think the squirrels have moved on to my Spit. Front carb float gave up this afternoon, and overflowed gas all over my engine compartment. Luckily no fire. The front jet was leaking a bit anyway, so I guess I'll just rebuild the carbs.
So... until that rebuild kit comes in, I'm now 0 for 3 "on the road". :crazy:
Parts finally all came in (or at least enough of them), and with a bit of fiddling and torquing tonight, the engine is now ready to go back in!
What the heck is the torque setting for the rocker cover hold down nuts? Why does the WSM specify a seemingly random assortment of torque settings? (For instance, it specs the gearbox mount torque but not the engine mounts!?!?)
And why do I care that much about the rocker cover torque? Because I solved all my rocker cover leaking issues years ago on my very first car (a '76 spit) by simply torquing down to the correct factory specification. Now I'm sensitive about the issue :smile:
jdubois said:
tdskip said:
Have help or going solo on the reinstall?
Going to get help again. Glad I had help pulling it out, as my hoist was a bit tippy!
Ok, so, I never was accused of having much patience. It was either go back to work after lunch, or play hooky, man up, and... :thumbsup:
(Now I just have to find some powder blue touch up paint. D'oh! Just a little scrape on the firewall.)
Got enough hooked back up tonight that I could turn the engine over with the starter and run a quick compression test.
175 185 174 171
Not too shabby for a cold test. I think my engine is fine.
I'd say you're good t' go!
One of the nicer things about an LBC is that one person can do about anything needed. It helps to have some appropriate job-specific tools but most work can be done single-handed. I do like a second set of eyes n' hands around, tho. If for nothing more than the company.
