TR2/3/3A welding slag in the carb tr3
sp53
I have less than a thousand miles on this tr3 and have had trouble keeping it running correctly. The gas tank is a new one out of southern California, and I did not flush it out prior to installation, and I keep getting welding slag in the carb bowls. The amount has lessened, but still coming in. I thought about putting a magnet in the gas tank and a paper filter for a while. I cannot tell if the slag is doing any damage and the first time I saw it I was shocked. I thought it was just a onetime deal, but I guess it just keeps getting flushed out of the welds. Any thought?
Jerry
Put a filter inline to the carbs. A magnet in the tank won't hurt anything. The tank does have a drain hole and you can flush it a few times with gas. Use a paint filter to catch the gas coming out and you can reuse it.
Jerry
TR3driver
Great Pumpkin - R.I.P
Why isn't it getting caught by the sediment bowl and screen?
I don't think welding slag is magnetic, but might be. A paper element filter is a good idea, though. I started running one myself after seeing all the tiny bits of rust that were making it through the bowl and screen.
SPACER
I don't have slag in the carb float bowls but I do have a bit of very fine black powdery stuff.
I have the usual AC fuel pump & glass bowl with screen but this powdery stuff is so fine it gets past the screen & into the carb bowls.
I would like to add a generic in- line filter.
Where is the best place to locate it?
Oh yes, late 59 TR3 with SU H6 carbs.
Thanks,
TR3driver
I prefer to have the paper element filter after the pump, so the sediment bowl & screen can still catch most of the gunk. So I trimmed back the hard line a bit, and reshaped it so I could mount an in-line filter between the hard line and front carb. It's a bit hard to find 1/4" filters at FLAPS, so I picked up a box of them on eBay.
LarryK
Spacer: Do you have any old rubber lines between tank to carbs? If so, the black powder may be alcohol eroded lines!
SPACER
Thanks Randall, good tips.
Thanks also to Larry, and yes I have some rubber tubing, about 4 inches just before the front carb. Will replace when I add the filter.
Thanks again guys,
TR3driver
One other point, last time I went through this with a buddy's TR6, he found what seemed to be a nice little reusable screen filter at FLAPS. It looked great with a clear center section (making the screen visible) and chromed ends, but it turned out that the ends were chromed plastic rather than steel and it broke after just a few months of service.
This is probably not the same filter, but it looked very much like this:
So my suggestion, if you buy that style of filter, then make sure the ends are steel, not plastic. Personally, I prefer the one piece paper element filters, but I suppose they do contribute some small amount to landfills every year.
dklawson
On my Mini I have the filter Randall shows above located between the tank and fuel pump. It is a fairly coarse filter and catches the larger sediment. The elements are replaceable and I keep spares (along with the end cap o-rings) in the car in case something happens on the road. I also have a cheap, translucent paper element filter right before the carbs. The disposable filter is the type that used to be very common on air cooled VWs. Together both filters do a good job of keeping debris out of the fuel pump and carbs. I also have the VW filter right before the carbs on the GT6 and the Spitfire.
Tr3aguy TR2/3/3A Welding in Frank’s bump stops Triumph 0
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
L Welding Bugeye Spring Base Plate?? Spridgets 1
S TR2/3/3A Welding hoods. Triumph 14
D Off Topic welding fumes Triumph 5
R TR2/3/3A Welding in the floor questikns Triumph 19
dklawson Antra Auto Darkening Welding Helmets? - 2016 Restoration & Tools 6
KVH General Tech Welding, Braising, Tacking Triumph 3
R TR2/3/3A Question on order of welding Triumph 31
S TR2/3/3A welding battery box Triumph 6
Rut TR4/4A On or off frame when welding in body panels Triumph 16
Jim_Gruber Bugsy II - Planning some Welding - Part II Spridgets 18
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B 1275 Block Welding Spridgets 14
G Filler metal used for tig welding ah aluminum shrouds Austin Healey 2
wangdango inner body panel painting/welding/etc Austin Healey 3
I bugeye bonnet welding help please Spridgets 11
J Welding advice please Restoration & Tools 9
boxfullofyertoys Thoughts on DIY welding/bodywork Spridgets 27
Morris Welding fun! Spridgets 9
K Modern Epoxy instead of Welding? Triumph 13
TRMark New Welding Helmet Restoration & Tools 3
M Welding 101. Triumph 1
hymodyne rear quarterpanel repair section welding Restoration & Tools 10
M_Pied_Lourd TR2/3/3A TR3A Floor Welding Question Triumph 8
T cast iron welding info and repair-FYI Triumph 1
ekamm welding tr3a inner sill Restoration & Tools 2
T Inner fender progress - welding pictures Triumph 17
germanmichel The story of the bad weld seams with MAG-welding.. Restoration & Tools 4
1965_MGB MIG Welding Anyone? Restoration & Tools 8
1965_MGB Gas Welding Anyone? Restoration & Tools 8
TRMark Welding Table Outlets Restoration & Tools 5
Popeye Welding butt joints... crack in weld after grindin Restoration & Tools 3
M Welding the Exhaust vs. Electrical Problems Spridgets 5
motofiaccone Welding in panels Spridgets 5
MGBGT_noob The great welding method controversy MG 12
M welding advice Triumph 5
T Aweman, I have a welding question, you there? Triumph 6
T Wedge Nearly done welding the TR8 floor repairs Triumph 15
T More welding quesitons - how much overlap? Triumph 9
T Question on seam welding - why not do it? Triumph 18
dhungerf Welding Patches? Triumph 11
A TR2/3/3A TR3 head welding Triumph 4
J Welding aluminum water neck Austin Healey 3
T First stab at welding Triumph 12
v8mgbal welding Spridgets 36
S Welding sheet metal Triumph 17
EastBoundJoe Welding newbie Spridgets 39
Popeye Welding: Butt- or Lap? Restoration & Tools 12
vping Welding to a rear axel tube. Can you? MG 17
