Weird fuel pump
vping
Slong with the stock SU and the other on emounted on the side curtain box, have a look at this one:
"Auto Pump" Made in NZ
I've got several of them on my used fuel pump shelf....seems they were installed by PO's at some time years ago when SU's weren't available.
Keeper or paperweight?
It would be a good paperweight that could be used as a fuel pump in a pinch.
[ QUOTE ]
[/ QUOTE ]
Me thinks you've already answered that one. /ubbthreads/images/graemlins/devilgrin.gif /ubbthreads/images/graemlins/jester.gif
Vping - if the pump works, consider mounting it under the car near the fuel tank and plumb it in line with the standard pump. Wire it and the stock pump to power through a single pole, double throw switch so you have a permanently mounted back up pump. The Auto Pump is a bit over pressure to use in place of the standard low pressure pump (the Auto Pump puts out around 4 psi or better). It will work fine in a pinch as Tony stated.
Cheers,
Kinda like this one:
PO must have had fuel problems. I think bad gas as they only started it every few years or so.
I pulled the carbs off last night to free them up. There is so much varnish in there I thing I'm going to start a furnture business.
Whoa! Looks like a gallon can of carb cleaner and a good soaking are in order!
You're a real glutton fer punishment, Vince. My hat's off to ya! /ubbthreads/images/graemlins/wink.gif
...and can you believe I want more of these little buggys.
*gigglesnort!*
"One's too many, a thousand ain't enuff!"
I'm arse to elbows in gas/grease/grime right now and loving it!
and some people don't see the fun in that! what's wrong with them? /ubbthreads/images/graemlins/grin.gif
Vince - just come play in my garage!
If I lived near you, I'd be your best friend!!
