Wedge Wedge Heads-Oil Pressure Gauge
DNK
Want to check the V8's oil pressure for more diagnostic. Where do I hook one up to on that motor?Where's the sender?
Mickey Richaud
There's a sending unit just starboard of the oil pump, on the timing cover. You should be able to see it, just below the alternator...
philman
I went to home depot for a t fitting, etc to hook up the pressure gauge and the idiot lamp also. spent a few bucks on parts. I also picked up a braided oil line to run to gauge I mounted in a pod on top of the dash.
DNK
DNK
Phil- I was thinking about the same thing. How a bout a photo.(Gauge Pod)
I checked the oil pressure and is about 15lbs at idle and between 40 and 50 at 2000RPM.Huw,my local guru said pressure is fine and he doesn't like the sound but says that since it is quiet at cool it might be a lifter.I need to pull the passenger side off when it is warm. Kind of a bugger with FI.
PATR8
I was tired of looking at my dash clock reading 1230 all the time so I took it out and mounted a Smith's oil Gauge there. I can not understand why one was never mounted on the car... clock or oil pressure... I beleive most people (Guys at least at the risk of sounding sexist)would pick Oil pressure
DNK
DNK
Just took it for a spin to warm it up.
The oil pressure at warm was :
Cold
2000RPM- 45lbs
idle (approx)- 15lbs
Warm
2000RPM-35lb
1750RPM- 25lbs
idle-750RPM-7-10 lbs
Idle is a little scary.
can oil pressure effect lifter operation?
Mickey Richaud
philman
I think if the idiot lamp is off your idle pressure is fine. Mine is flickering off at warm idle, and the engine is an unknown. The engine in my rangie makes valve train noise, but what I am hearing is different.
DNK
DNK
Well I drain the oil and refilled using the correct amount this time. I prefilled the new filter before install.Added some lifter quiet too and I removed the passenger side valve cover (those gaskets are a pain) and checked the lifters. All rockers are moving and push rods are jumping.
I restarted it to check for leaks but have not let it get hot yet.
Somebody made a remark about turning the oil pump after draining. Please comeback with more info.
Mickey, you got part one of the above link?
Side note- Where can I get new seals for the drain bolt. What a big bolt.
Mickey Richaud
Scroll to the bottom of the page; all parts are linked there.
Mickey Richaud
Hey, I understand. Can't tell you how many times I've searched for something, only to have my wife follow right behind me and produce it from its "hiding" place right out in the open!
Must be a guy thing!
DNK Wedge Wedge heads help Triumph 15
PATR8 Wedge A test for the Wedge heads Triumph 14
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
David Townsend Wedge Limited Edition Wedge Prints Available Triumph 0
jfarris TR2/3/3A Thumb Screws for Wedge Side Curtains Triumph 4
PATR8 Wedge Help.... Wedge stalling out Triumph 1
Got_All_4 Wedge I need a new one of these. Wedge ac experts Triumph 5
PATR8 Wedge Where have all the Wedge owners gone Triumph 5
Marvin Gruber TR2/3/3A Need a pair of Wedge type side curtain mounts Triumph 3
aeronca65t wedge parts car for sale - NJ TVR 2
mgedit Wedge Wedge Style Sidescreen ... Picture Request Triumph 8
DNK Wedge Wedge Triumph 3
T Wedge The Wedge Shop Single Turbo TR7V8 build Triumph 3
John_Mc Wedge Nice Wedge Triumph 6
glemon Wedge Is that all the love a Wedge gets? Triumph 14
DNK Wedge Wedge WP Triumph 2
PATR8 Wedge Wedge help needed Triumph 7
Darrell_Walker Wedge Wedge radio mounting Triumph 16
Darrell_Walker Wedge Drove the Wedge to work today! Triumph 6
K Wedge Taking the wedge to the Cape- Triumph 4
Darrell_Walker Wedge Reassembling wedge front suspension Triumph 6
glemon Wedge Low Mile Wedge Triumph 7
Darrell_Walker Wedge Removing Wedge strut cartridges Triumph 13
justin_mercier Wedge Took the wedge out for a little spin. Yay! Triumph 14
Darrell_Walker Wedge Wedge wheel adapters Triumph 14
Darrell_Walker Wedge Thought exercise - a wedge as a daily driver? Triumph 86
jclay Wedge Texas Wedge Ralley and Picnic! Triumph 10
John_Mc Wedge Wedge parade Triumph 7
WedgeWorks Wedge Wedge Tree Triumph 9
DNK Wedge Wedge Pumpkin Triumph 18
T Wedge BMW Recaro seats in a wedge Triumph 22
deadair Wedge wedge mount side curtains Triumph 11
DNK Wedge Wedge liners Triumph 10
philman Wedge good looking wedge on pdx craig's list Triumph 11
G Wedge A/C TVR 4
DNK Wedge Wedge PS Hoses Triumph 0
G Leven Hood Cover for a Wedge TVR 1
T Wedge Another Wedge head has joined us Triumph 60
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
P Wedge shaped Master Cylinder Reservoir 76B MG 0
JFS Wedge Wedge Glove Box Triumph 6
tr7andtvr Wedge rear end ratio swap? TVR 1
DNK Wedge Wedge and TRF Carpet and others Triumph 9
ChrisS Wedge [no this doesn't belong in the 'rumph forum] Spridgets 5
DNK Wedge Wedge Cover emblem Triumph 3
T Wedge Wedge Completes 24 Hours of Lemons Triumph 1
philman Wedge wedge rear suspension Triumph 8
jclay Wedge Wedge Technical Site Triumph 5
T Wedge Latest wedge has landed. Triumph 10
