t8nwa
I finally get mad enough at my water choked Stromberg to buy the weber kit off ebay with electric choke. The Stromberg would start with ether then die. The weber was a 34 DGEC not the normal 32/36. Well, after numerous trips to the store to get tubing, piping, PCV valve, gasket, nuts, elbows, and a tee, I finally have it all hooked up.
I turned the key on for a few seconds for the electric fuel pump to fill the new weber and adjust the pressure regulator. Then something amazing happened. First turn of the key, the car started. Totally shocked me.
The issue, the idle is REALLY fast with the choke on. 5k fast.
How do you adjust the choked idle speed? I get a one year phone support from weber, but they are not open on the weekend. Hopefully someone here knows the tricks.
If someone wants all the details of this $280 shipped special, let me know.
thanks
Alan
thanks
Alan
