Michael J.
I've pulled the heads off two v-12s in the last few months and was shocked at the amount of corrosion damage to the head gaskets.
On both engines, the head gaskets literally crumbled away for all areas that were not sandwiched between the head and block.
A couple of years ago, I saw a program on "Shade Tree Mechanic" on TNN that talked about using 100% Propylene Glycol coolant without water to minimize corrosion in aluminum block engines.
Does anyone have any experience using coolants other than Ethylene Glycol? How about suggestions on preventing the corrosion associated with 50-50 water mixtures?
Prestone Low Tox Antifreeze/Coolant is Propylene Glycol based, but the label still calls for mixing with water.
What do you think?
What do you think?
