Hi Guest!
Thank you. I sent a response tp you privately.I have a pair but they are in bad shape
Roscoe--I have a question. Of course this is only for BN1/2 cars. I modified a sidescreen set to replace the pliable plastic with the vinyl trim with a solid piece of lexan. I retained the chrome trim pieces but made no provision for a flap or a hole for reaching in to open the door (I may do but got lazy). My solution was to make a "key" out of a 1/8 metal rod that I can slip past the edge of the sidescreen to push on the inside door lever. Works well and I keep it in a secret place inside the rear fender well with a couple of magnets. Works great.....but how were you supposed to open the doors with those early solid side screens? Mine are certainly too well fitted to squeeze a hand in.
