Not too sure how rear axle shims would cause a car to sway at the rear but every days a schooldays.My best guess without seeing it myself is somebody did NOT shim up the rear axels correctly. This is
weird but would explain a lot/easy to check.
Mad dog
This has been my exact point, there is no wheel movement or up/down movement. Tyre pressures are 30psi. They are Firestones and new but I believe classic Firestones are made by a UK franchisee now so possibly of far less quality.just watched the videos again, I can't see any movement of the wheels in relation to the body,
the centre hub cap is moving with the body, my money is on the tyre walls flexing, have they got enough pressure in them.
Just read a few reviews on these tyres, not sounding too good. They are prone to very soft side walls, and a lot of run out (tread wobble),This has been my exact point, there is no wheel movement or up/down movement. Tyre pressures are 30psi. They are Firestones and new but I believe classic Firestones are made by a UK franchisee now so possibly of far less quality.
If you read the thread and see the link to the video you will see the problem and the comparison with the red TR which is rock solid. It’s nothing to to with ‘they all do that’ - Triumph couldn’t possibly ever have raced, rallied and sold huge numbers of cars if they wobbled at a light sideways push. The handling isn’t squirrelly it’s all over the place as the rear body is being thrown about 6” either way at the slightest chance. There is no control of that other than steering it out or careful braking either of which could lead to disaster on a 2 way road.You‘re worrying about nothing. I can do that with any car with 70 profile tires. We have gotten used to 50 and even 30 profile tires on family cars…those will not do that.
As for the squirrelly handling, I bet it has toe-out, which makes a car dart all over. Bring the toe to zero or slight inward and handling will improve. Of course, there could be loose steering parts, but you can’t detect that by pushing the car. You must look under at each part as someone rocks the steering wheel gently back and forth.
Hard steering is an indication of a bent vertical link or binding trunnion. These are also easy to miss if the restorer was not intimately familiar with TR suspensions.
Finally, a TR set up properly should be stable and easy to control…but it cannot be compared to a modern car. It’s 75 year old technology. The zero caster suspension means you have to drive it. Modern cars drive you!
A very good idea.You're in Essex, UK. As we're all just guessing, and haven't actually seen the car, why not contact the Triumph Club of Essex (Andy Dimbleby) and have someone with TR knowledge do a hands-on inspection? Seems that would give you some good feedback on the car, and what it may need, before you buy it.
Tom M.
If you see no difference between the a heavy push on the red red car and a light push on the yellow - and the likely effect on handling - then I would leave it there if I were you!Looking at the all the videos I see no problem with the car.
