tinman58
We'll I got it figured out! The new Monroe tube shock that bolts thru the body and bolts to the shock mounts does not line up good at all. I checked EVERYTHING and I did install it correctly. The tube shock was out of alignment causing the shock to bind up solid. So after sitting back and reevaluate everything, I removed the "new and improved" set up, and re installed the old lever shocks. The car rides nice and squats down a little bit on acceleration. I love it...... Bad news is I removed the door check thingy to keep the door from opening to wide, all I had to do was adjust the door some, we'll the door was swung oped a little to wide and now the beautiful door has a big crease in it. That will be fixed soon, but what a disappointment.
