Continuing on my vapor-lock question (from the fuel line thread), thought I'd start another one. Are those standard carburettor heat-shield panels usually effective if one has a large exhaust header under them? I haven't explored how warm the float-bowls are getting or anything else in that area is, but I guess I'm wondering if this is ever a problem. Yes, I'm still investigating my fuel line and filter (and that filter is too close so I've done an experimental wrapping with heat-tape). I shall be re-routing the fuel line (and probably changing it to another material). [1275cc, dual HS2s and new electronic fuel pump at that tank]
Thanks.
- Mark
Thanks.
- Mark
Hi Guest!
