After rebuilding the 3 engine we set the intake and exhaust gap settings at .010". With an upgraded cam what should the ideal range be.....014 or .016? Anyone upgrade their cam and can offer advice? Karl
My cam on the old race TR4, (should be the same as your TR3) was grind # an66 with a cam lift of 298 and valve lift of 448, the valve lash (setting) was .018 hot, don"t have a cold but would go with .020 to start until it warms up. Ran 2 inch SU.s off a Volvo and would go like the devil after 2000 RPM,s
What intake manifold did you use when you ran the 2" SU's? I bought a TR4 intake manifold on Ebay that had the ports widened to take 2" and toyed with the idea of putting 2" on. Do you remember what Volvo's used them? I've heard it said that the engine would be "over carbueurated " with 2" SU's and that the 1 & 1/2" were adequate? Any issues with running them?
