TR2/3/3A Valve gaps...fast road cam...TR3
karls59tr
Bronze
After rebuilding the 3 engine we set the intake and exhaust gap settings at .010". With an upgraded cam what should the ideal range be.....014 or .016? Anyone upgrade their cam and can offer advice? Karl
Twosheds
I used the gap recommended by the grinder for that particular grind cam. It was listed on the grinder's website.
Do you know who ground the cam and what the grind is? Iskendarian lists the gap on their website, maybe other grinders do as well.
Twosheds
I sold that car, but I still use that photo for my avatar.
It has an Iskendarian "666" cam. I disremember what the valve gap was. It wasn't the same as the stock gap, though.
trrdster2000
My cam on the old race TR4, (should be the same as your TR3) was grind # an66 with a cam lift of 298 and valve lift of 448, the valve lash (setting) was .018 hot, don"t have a cold but would go with .020 to start until it warms up. Ran 2 inch SU.s off a Volvo and would go like the devil after 2000 RPM,s
Wayne
PeterK
My TR4A TT fast road cam (278 duration) is .013" intake and exhaust.
You really need to check with you cam profiler to be sure what's right for your cam.
K
karls59tr
Bronze
What intake manifold did you use when you ran the 2" SU's? I bought a TR4 intake manifold on Ebay that had the ports widened to take 2" and toyed with the idea of putting 2" on. Do you remember what Volvo's used them? I've heard it said that the engine would be "over carbueurated " with 2" SU's and that the 1 & 1/2" were adequate? Any issues with running them?
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
S Price check on TR3A valve cover Triumph Classifieds 0
H BJ8 Heater Valve/Control Tap Austin Healey 3
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
G Valve adjustment and easiest way set cam position Austin Healey 15
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
dbenichou289 TR2/3/3A Valve seats Triumph 8
steveg TR6 Adding a PCV valve Triumph 5
D TR6 Valve cover paint Triumph 5
B TR4/4A New valve gears/timing Triumph 21
