When posting a classified ad, you MUST select a prefix from the drop-down next to the subject line. If you don't you will get an error and your ad will not be posted!
Okay, what do I use to run the vacuum line from the manifold to the distributor? Is this a soft line, or some sort of hard metal line? The line on my original 948 was metal, but its ends won't fit with the new distributor or 1275 manifold.
Driver or show car? Original was hard pipe, practical is rubber line. Buy a long enough piece (it's cheap) to play with so as to get the "look" you want, then trim to fit.
I used a "hard" vacuum line from PepBoys or similar, you heat it up and it bends to whatever. I like it, rubber fittings either end, it's very thin and inconspicuous.
This car is a driver (Bugeye w/ 1275, disc brakes, etc) so originality is not a big issue here. I'll check in with my local parts store and see what they have. A soft line makes a lot of sense.
