Vacuum line?
drooartz
Okay, what do I use to run the vacuum line from the manifold to the distributor? Is this a soft line, or some sort of hard metal line? The line on my original 948 was metal, but its ends won't fit with the new distributor or 1275 manifold.
Jer
I used a rubber line on my 1275 when I switched from a mechanical advance (early original 67' distributer) to a petronix, never had a problem.
G
Just make sure you don't use the really thin windshield washer rubber line as it will collapse.
Pythias
Driver or show car? Original was hard pipe, practical is rubber line. Buy a long enough piece (it's cheap) to play with so as to get the "look" you want, then trim to fit.
jvandyke
I used a "hard" vacuum line from PepBoys or similar, you heat it up and it bends to whatever. I like it, rubber fittings either end, it's very thin and inconspicuous.
drooartz
drooartz
This car is a driver (Bugeye w/ 1275, disc brakes, etc) so originality is not a big issue here. I'll check in with my local parts store and see what they have. A soft line makes a lot of sense.
Thanks for the replies!
M Vacuum Line on a 948 Spridgets 4
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
W BE vacuum advance line and fittings Spridgets 2
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
Tinkerman TR2/3/3A 1960 TR 3A vacuum advance line installation Triumph 7
C Vacuum line routing for brake booster Austin Healey 5
M New vacuum line Triumph 16
Tinkerman I Having A bad vacuum advance line day Triumph 5
Tinkerman TR2/3/3A TR3A Vacuum Advance Line Triumph 2
mrv8q TR2/3/3A TR3 Vacuum line Q Triumph 4
C vacuum line routing Triumph 12
angelfj1 petrol and vacuum line support Triumph 11
J Dizzy vacuum line, manifold drain lines routing? Austin Healey 7
tony barnhill '63 Midget Hard Vacuum Line Spridgets 16
Bret Vacuum line fittings? MG 10
1 Novice question about vacuum advance line. Austin Healey 26
RobSelina vacuum and vent line diagram Spridgets 5
M 1990 XJS Vacuum Line Routing Jaguar 1
Sopwith_Camel MGA booster Vacuum MG 8
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
B Vacuum Source Austin Healey 4
WHT Vacuum Advance Pipe Austin Healey 7
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
JPSmit Today's question - vacuum advance Spridgets 2
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
B Vacuum Advance Pipe Austin Healey 2
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
J TR6 Vacuum Retard question Triumph 1
R TR6 Thermostatic vacuum switch Triumph 3
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
S TR2/3/3A Vacuum leak Triumph 19
B Vacuum Servo Austin Healey 19
D TR2/3/3A Vacuum connection at Carb Triumph 23
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
D TR2/3/3A Vacuum advance tube Triumph 6
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
B TR6 Timing using a vacuum gauge Triumph 13
T MGB Vacuum advance and Electronic ignition conversion MG 5
SherpaPilot TR6 Vacuum Gauge Timing Triumph 5
