Vacuum Leaks
mylesw
Hello
What is the best way to test for vacuum leaks on a BT7 (HD6 carbs)? I have a vacuum gauge somewhere and could connect but don't know where is best...
Thanks
Myles
Keoke
Hi
Check with your local automobile parts/supplies stockist he will have products that can be sprayed around on the carbs and manifold that are fairly safe to detect the source of a leak.
BOBBYR
I've used window cleaner or water from a spray bottle for this - if there's a vacuum leak, the engine will stumble.
Hi Guy's on checking for vacuum leaks, I like to use a little starting fluid. If you put a portable tachometer on engine while using the fluid, you can usually find event the smallest of leaks by an increase in rpm . Remember your dizzy and brake booster also get their vacuum from the manifold and carbs . Hope this helps Bobby R
Keoke
Hey Bob, I'm getting a mental picture of a guy checking with a lit torch. Ah, You guys are too much .
Bobby R
NO Bobby R :
Just make sure the engine is cold and the torch is unlit--:excitement:
Michael Oritt
A can of WD-40 with the thin "straw" attached would also do very well and not be explosive.
aeronca65t
I always use Micheal's method. WD-40 is nice and safe.
Michael Oritt
Nutmeg--
You're right and so is propane but the concept is to spray it toward the carbs, not an open flame....
Michael Oritt
Tom--
Sorry for the sarcasm....
M
mylesw
Used the starter fluid method and appear to have some leaks where the spacer blocks attach to the manifold. I've bought some new spacers and gaskets from Moss but the spacers appear to be made of plastic these days... Question is, should I use gasket sealant when attaching these to the car?
Also, took the opportunity to do a compression test on the cylinders and 4 of them are at 120 psi and one at 105 and another at 110. The reason I was looking for vacuum leaks is because I have been getting a backfire through the carbs. Could the low compression on the two cylinders cause this? Note that before doing the compression test I checked and set the valve clearances.
Thanks
Myles
NutmegCT
You'll get many good replies on the gasket sealant question, but my first suggestion would be to call Moss Motors and ask. If they say yes, then ask what sealant they recommend.
Another thing to check when you start the work - is the carb to manifold junction surface flat (not warped), to allow perfect mating of the surfaces? I had a major vacuum leak due to a warped (heat?) carb base; had to true up the surface by rubbing across sand paper on a flat steel plate. My brain has failed - can't remember the word for that process.
Tom
steveg
Tom
Lapping?
CLEAH
Decking or surfacing. I think lapping involves two pieces of material, such as a valve and a seat.
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
sundown TR6 1973 TR6 vacuum leaks Triumph 1
M Vacuum Leaks Spridgets 9
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
B Vacuum Source Austin Healey 4
WHT Vacuum Advance Pipe Austin Healey 7
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
JPSmit Today's question - vacuum advance Spridgets 2
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
B Vacuum Advance Pipe Austin Healey 2
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
J TR6 Vacuum Retard question Triumph 1
R TR6 Thermostatic vacuum switch Triumph 3
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Vacuum Line on a 948 Spridgets 4
S TR2/3/3A Vacuum leak Triumph 19
B Vacuum Servo Austin Healey 19
D TR2/3/3A Vacuum connection at Carb Triumph 23
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
D TR2/3/3A Vacuum advance tube Triumph 6
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
B TR6 Timing using a vacuum gauge Triumph 13
T MGB Vacuum advance and Electronic ignition conversion MG 5
SherpaPilot TR6 Vacuum Gauge Timing Triumph 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
Gerry M TR6 Vacuum Lines Triumph 8
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
J TR2/3/3A Vacuum lin Triumph 13
bigjones Vacuum advance on a 1500 Spridgets 13
sundown TR6 1973 TR6 vacuum reading Triumph 2
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
B TR6 Vacuum retard late TR6 Triumph 4
