I ended up pulling the gearbox because there was a spring and other starter parts that were too big to remove with the gearbox in place. I decided that with box out I may as well upgrade the clutch while I'm in there. This is a TR6 box in a TR3. After the box was reinstalled I realized that the shift lever was jammed in 4th gear and would not budge from the straight up position?? I came to the conclusion that I must have installed the clutch disc backwards as I had heard that it sometimes can happen on installation. So I pulled out the gearbox again and discovered that the clutch disc was installed correctly! So I now have the gearbox on the bench. I pulled the gear shift lever expecting to find that little spring and button on the bottom to have jammed up and caused the problem. But no they were in good shape. So now I am going to remove the top cover and see if I can find out what the issue is. Not sure how to proceed or what to look for never having messed with the guts of a gearbox before. I found this online: Check rail alignment. Ensure the notches on all three selector shafts are perfectly lined up in a straight horizontal line, meaning they are all in their neutral Detents. Test with a Pry Bar or large flat head screwdriver to move the forks(about 30 lbs of force is usually required) to make sure the rails can slide into gear and return to neutral. Where exactly do you pry? Any advice on doing this and what to look for? Karl
