Banjo
.....Hopefully.
Saturday, accepted new job
Sunday, decided BMW needed to come out of hibernation and be back in regular service (33mpg vs 12mpg in the truck)
BMW was stone dead. jump-stared and it ran ok. thankfully I wasn't a victim of Ethanol, but the battery was frozen solid.
Monday, took the battery in to work and let it thaw. Ordered the power steering rack that was leaking profusely (the reason I parked it)
started the 12 hr shifts.
Tuesday, tried charging thawed battery. Seemed to be taking some charge, but I didn't trust it.
Wednesday, worked.....
Thursday, Stopped at lunch time and picked up a battery. put it in after work and car is alive again. noticed a bad noise in the front of the engine.
Friday, finally had a day off, but had a lot to get done. Picked up the rack at the parts store.
Saturday, went in to the shop and installed the rack, and aligned the car. diagnosed the noise as a bad water pump. Called the parts store and ordered one.
Today, went and picked up the pump and installed it in the driveway. Removed the AC compressor belt as the pulley on the compressor is loose and I can't fix it right now.
Took the car for a test drive....
OK.... I hope she's up to the task now. Time to stand by the fireplace and thaw out.
:laugh:
