Rob Glasgow
Before I began the restoration of my 1960 BT7, it sat unevenly in the rear. I measured the distance between the ground and the top of the rear wheel arches and the left side was 3/4" less than the right. When I removed the rear springs I found the left spring had about 1/2" less arch than the right. Thinking that was the problem, I had both springs re-arched at a local spring shop. I had them add 1 inch to the right spring and 1-1/2 to the left. After reinstalling them, the car still sits unevenly with the same 3/4" lower on the left side. Currently the engine is still out of the car and body panels and interior are not installed. The rear axel sits hard down on the rubbers mounted to the upper surface of the frame so the frame cannot sit any higher than it is now. In other words, putting more arch in the springs at this time will not allow the frame to sit any higher.
So what can I do to correct the issue? I'm hoping that when I reinstall the engine, body panels and interior, there will be enough weight on the rear to lift the axel off the frame and the frame will sit level. Any other ideas?
