FINALLY! I'm about to finish wiring the dash on the '73 MGB, so I can install it and move on to the carpets and the rest of the interior.
There are two wires yet to be identified. Both are green with a white stripe. They both emerge from the harness next to each other; both have a male bullet connector, and are located roughly between the fresh air vents and the glovebox. I've been able to trace one with a volt-ohm meter to a wire in the engine compartment, near the coil. Its end has a female spade terminal. Don't know what it's for. And I haven't been able to find the "other end" of the other green/white stripe wire.
Should these two be connected together? And what are they for?
Diagram and wire code info shows green/white are for turn signals, and they are working fine, including the arrow indicators on the dash. However, when I turn on the hazard flasher, only the right side blinks (not really concerned about that, though).
Thanks for any help,
Mickey
Mickey
