Twin HS4 Su's leaking fuel
George P
I need some help here,
My twin HS4's were recently overhauled and refitted to my 79 Midget1500
Ever since then I get fuel coming out of the front Carb overflow
I contacted the company that did my carbs and the sent me a new float bowl top with needle valve and float, I fitted this and I still have a fuel overflow.
I cleaned out the float bowl and checked the needle valve was free to move. Still fuel was leaking.
I fitted a nice fuel filter in the line. Still I get fuel leaking.
I then resorted to violence and shimmed up the needle valve seat 1/8" and I still have fuel leaking.
I have the original mechanical fuel pump fitted
What's happening here ?? What else can I do ??
I'd be grateful for any help.
And just on the side I have a screw inserted into the chrome cap of my rocker cover, is this correct ??
JPSmit
George, I am not sure that this picture can really help. The rocker cover is lovely and I see the vent for the engine but, can you post a pic of the carbs themselves?
thanks
G
George P
thanks
Thanks JP, hopefully you can see fuel leaking from the front float bowl top. Also I'm showing the carbs and the new filter.
G
George P
thanks
This may show the fuel leak better.
RickF
Does the float actually float?
Also, I just noticed you have no clamps on your fuel lines. That could be what's leaking. In my opinion you need some clamps, no matter how tight the lines feel when you push them on the tube. 😁
G
George P
Thanks Rick, yep no clamps, that line was put on as a temp measure. The real line has clamps indeed.
I tried two floats and two needle valves and two float bowl tops, all do the same Leak!!!
Mickey Richaud
George -
See my post regarding setting float level over on the MG side. May be your issue.
Mickey
G
George P
Next thing to check is fuel pump pressure. SU's like 2.5 psi.
Thanks Rick, I watched the video. My float bowl top is No2277 and does not have the bendy adjuster, I have just ordered an earlier 2276 with the spring arm (Picture) in the hope that it might cure my problem. Not sure how to check the fuel pressure
Coalhod
Harbor Freight sells a fuel/vacuum tester (around $14.00) which can be tee'd into the fuel line before the carbs. My only other thought is possibly using a Viton float (Joe Curto and Moss sell these) as I have found the ethanol blended gasoline will deteriorate the original type float.
G
George P
Meanwhile I glued in place a wee packer here on my spare float here to see if that would help!
G
George P
Well that did not work seems like it shut the fuel of altogether so back to square one. I'm still losing fuel even after switch fron and rear floats and needle valve.
Need help before I catch fire!!!!
Bayless
Are you certain the float actually floats? Could it be a leaky gasket? If none of these then I think you are down to checking the pump pressure although if a real SU pump I don't think that is likely.
zabond
is it actually leaking out the overflow vent[which is behind the small metal plate where your fuel line goes on] or is it leaking out of the gasket area? as that gasket looks a bit dodgy to me, sorta home made
Russ
Jim_Gruber
I ran into this several weeks ago. I installed new Ethanol Resistant Floats and upgraded to the "Superior" Gross Jets with the Ball Valve. Adjusted Float Height correctly. Started Engine Gas leak from Front Carb. Changed back to old Vitron Tipped valves on front carb, leak stopped and moved now to rear carb, crap, Changed back to Vitron Tipped Valve on rear, reinstalled old valves and leak went away. Problem solved.Order new Vitron Tipped Float Valve and issue will be solved.
JamRBrisk
Front HS4 carb leaks through at 4000 rpm, it’s the vent not the gasket, put in new vitron, still leaks, submerged float in jar of gas overnight with no leaks floats fine, adjusted float way high to ensure closure of vitron valve, still leaks at 4K.
Pythias
hmmmmm...... years ago I had a similar problem... .. in the end it turned out to be a fuel pump that put out 7 pounds of pressure instead of 3.. the problem didn't show up until I had the carbs rebuilt... I've since installed a pressure regulator (NOT those ROUND CHEAP ONES from MO#$) but a good Holley...
CJ-Mac
2 years later, did you ever get to the bottom of it?
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
M MGA RHD twin cam steering pinion MG 0
B Anyone have a Europa Twin Cam for sale? Lotus 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
D Experience with Mallory twin point distributor. Austin Healey 5
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
B Twin OH Cam for the BIG Healeys Austin Healey 15
M MGA MGA Deluxe / Twin Cam brakes MG 2
David Townsend MGA Rocket Ralphie's Twin Cam MG 4
glemon MGA Twin Cam MG 4
David Townsend MGA MGA Twin Cam Illustration MG 0
T Twin Cam Healey Austin Healey 20
Brinkerhoff MGA MGA Twin Cam handbrake parts MG 3
P MGA Where is my Twin-Cam? MG 15
Foura TR4/4A TR4A Exhaust - Twin or single? Triumph 8
P MGA MGA Twin Cam owners manual. MG 1
aeronca65t MGA MGA Deluxe/Twin Cam? MG 9
Marvin Gruber MGA Pulled the trigger. Bought a MGA Twin Cam MG 12
Marvin Gruber MGA MGA Twin Cam MG 11
PAUL161 MGA STOLEN MGA TWIN CAM!!! MG 0
vette Twin Reservoirs Austin Healey 2
S TR6 twin dgvs on a tr6 Triumph 26
glemon MGA MGA Twin Cam MG 5
eschneider Twin cam crankcase pressure low, VC pressure high Lotus 21
S MGA 1959 MGA Twin Cam on eBay...?? MG 17
theleisure twin-engined-4x4-1966-twini-cooper-s British Motor Corp 1
glemon Is this a Twin Cam MG 8
T Twin barn finds-one is a Jag. Jaguar 3
S Ford Crossflow on twin 40s. Help needed! Other British Cars 3
B MGA Pic .of my old MGA twin cam MG 10
GeeBee1 Twin Cam - not much time left MG 34
aeronca65t "Real" Escort Twin Cam Other British Cars 18
G Wedge TR7 with twin webers Triumph 1
eejay56 Linkage for twin SUs Triumph 1
B Sprite Twin Tone Horns Spridgets 16
D Weber versus twin SU's British Motor Corp 1
K MGB 80 MGB carb conversion to twin SU's MG 16
GT6_Mark Hot Running Problem – Twin Stromberg Triumph 16
C Europa Twin Cam Autocross Car Lotus 3
poolboy Twin Cam MG 3
S 59 MG A Twin-cam MG 8
eejay56 Weber DGV or twin SU HS4s Triumph 12
C TR6 My Twin Turbo TR6 Triumph 8
RobT Twin Cam Timing Chain Adjustment Lotus 14
L Spitfire Twin cooling fans on the Spit... Triumph 6
eschneider TR2/3/3A empty float bowls - TR3 with twin SU H6 carbs Triumph 19
