TR2/3/3A Turn signal wiring
RonR
Folks,
I had the front nose off my TR3A and I am having problems getting the turn signal wiring reconnected properly. Matching up the color coded wires does not seem to work.
The wiring harness was replaced a few years ago.
From the steering column, I have the following wires for turn signals:
Green with Brown stripe
Green with White strip
Green with Red strip
From the left front turn signal, I have:
Red
Green with White stripe
From the main wiring harness, I have the empty connectors.
Green with Red stripe
Green with Brown stripe.
Red
Green with Red stripe and Green with White stripe (double connector)
Any suggestions would be greatly appreciated.
Thanks.
Colors out of left front turn signal should be solid red (parking light) and
green w/red (left turn)
Colors out of right front turn signal should be solid red and green w/white (right turn)
You can find corresponding wires from the harness at the multiple connectors located
next to the horns on each side.
Attached is a wiring diagram that might help.
Frank
