TR2/3/3A Tubes in steel wheels?
bikesandcars
Step 1 for getting my 1960 TR3 back on the road is new tires.
This is probably a silly question, but for tubeless tires do factory TR3 Steel wheels take tubes?
If so which do you recommend?
If not what valve stems do you recommend?
DavidApp
Hello bikesandcars
The TR3 steel wheels do fine with tubeless tires. Not sure about the valve stems. I just had the tire shop use what they normally use. It would be worth checking that the rims run true by mounting each wheel in turn on a front axle and spinning it to check for run out. I went through a few rims before I found a good set. Tire size is important if you plan to have a full size spare.
This is the tire size I used and it just fits in the spare wheel compartement.
David
Geo Hahn
Yeah, tubeless works fine. I just used standard rubber valve stems that you pull through. I also measured run-out: all were within spec but the worst one became the spare and the two best went on the front.
Geo Hahn
Maybe. That isn't always necessary over the life (age) span of the tires - my thought was to at least have the best wheels at the front most of the time. In any case my spare would not rotate as it is always the best tire from the most recently replaced set.
B
bikesandcars
Thanks! I ordered 165HR-15 VREDESTEIN SPRINT CLASSIC tires from tire rack. They are 165/80. Same size as what was on there.
Gonna mount them myself and use dads old static balancer from his shop to be period correct :smile:
DavidApp
I was going to powder coat my wheels but sprayed them when I priced powder coating locally at $125.00 per wheel. That was the price even though I had them sand blasted ready for coating. Should have known by their advert "Pimp Your Wheels"
The spray finish looks great.
David
Geo Hahn
Yeah, $125 seems a but much. Mine were $75 apiece including sandblasting. Went with a color very close to the original Spa White. Spray silver holds up pretty good but white paint is difficult to keep looking nice with brake dust and such.
B
bikesandcars
Good choice IMO. Last time around I had the wheels powder coated which both looks good and simplifies maintenance.
I'm debating what to do for wheel paint. Right now the car is a time capsule, original and never restored but showing some age.
Not sure I even want to paint the wheels yet. They were the period silver, a little rough right now.
I just want to replace the rotted rubber, make sure the wear items like brakes are good and drive it a bit.
B
bikesandcars
I've decided to paint the wheels, she deserves some nicer sneakers.
I need to get my shop set up but I have a compressor / blast cabinet, maybe this is a good reason to get that done and get these done.
I'll probably use VHT rattle can, I have a spray gun but not sure I want to load it / clean it if rattle can will hold up.
I'll use Argent Silver. I assume the original finish was single-stage (no clear). Any recommendations for if I should clear coat them and what sheen to use? (gloss?)
Geo Hahn
Back when I painted some steels wheels I used (the redundantly named) Argent Silver in a can followed by a clear gloss. I likes the result and it may have been easier to keep clean that it would have w/o the clear coat.
DavidApp
My rattle can wheels with no clear coat a year+ on the road, 1500 miles. No special treatment except washing off with soap and water.
David
B
bikesandcars
Thanks for sharing! I shopped around for some quotes: $130 a wheel for refinishing!!!! I'll save that money for new mini-lites down the road.
It's looking like I'll do the VHT argent silver and gloss clear.
mrv8q
I used Eastwood primer, Argent silver, and clearcoat rattle can 15 years ago and it has held up well. It is time for a refresh, though...
D TR2/3/3A Tubes in steel wheels? Triumph 15
Scotsman TR2/3/3A Should inner tubes be used with TR3 OEM steel wheels Triumph 3
T Steel wheels and tubes Triumph 12
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
D TR2/3/3A Pushrod tubes Triumph 4
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
TulsaFred Proper attachment of Demister tubes and vents Spridgets 3
Michael Oritt Tubes in, Box out Austin Healey 10
Keith_M demister tubes and vents Spridgets 2
doc50 TR2/3/3A Stator Tubes Triumph 12
R GT6 Early Gt6 Pushrod tubes Triumph 14
BlueMax Wiper Chain Tubes Spridgets 3
Lukens TR2/3/3A Are there different lengths for stator tubes? Triumph 3
Got_All_4 General Tech Storage of inner tubes Triumph 4
P New tires & tubes Triumph 23
A TR2/3/3A TR-3A wiper lubricant [tubes and cable] Triumph 1
M_Pied_Lourd TR2/3/3A TR3A Rear Bumper Distance Tubes Triumph 11
S TR4/4A Leaking push rod tubes, TR4a Triumph 7
af3683 Quality Inner Tubes Austin Healey 2
af3683 Moss Wire Wheel Inner Tubes Triumph 8
sail Hand Mounting Tires/Tubes Triumph 12
T inner tubes Austin Healey 13
Jim_Gruber SU Carb overflow tubes Spridgets 11
M wheels, tires, and tubes Triumph 8
GBRandy Wedge TR8 Power Steering Tubes - available soon Triumph 5
mountainman TR2/3/3A TR3 Drain Tubes Triumph 8
R Tires and tubes British Motor Corp 4
S Breather Tubes Jaguar 3
A TR4/4A TR-4 cylinder head push rod tubes Triumph 2
P Manifold and Carb overflow tubes on a BJ7 Austin Healey 18
D Tubes req'd w/ wire wheels on Midget?? Spridgets 6
dklawson Wire Wheels & Tubes Triumph 8
Y Using inner tubes in radial tires Triumph 25
Lin BJ8 convertible drain tubes Austin Healey 7
Baz Wire wheels, tires and tubes.... Restoration & Tools 7
M Inner tubes needed?? Austin Healey 22
AUSMHLY drain channel tubes Austin Healey 15
Y tires & tubes Triumph 4
miranda tires on a 100-6, inner tubes or not? Austin Healey 2
P SU CARB Overflow tubes MG 6
M 69 XKE tire tubes and rubber spoke end strips Jaguar 2
K TR2/3/3A The steel head stud washers? Triumph 7
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
S TR2/3/3A brass fitting from a steel brake line Triumph 2
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
Guido36 Stainless Steel Bumpers Austin Healey 5
B Stainless Steel Exhaust System Wanted Austin Healey 5
