TR5/TR250 Trying to figure out rear transmission mount with a J type tranny
Got_All_4
first of all I have a later Tr6 frame under my 250. Installed the tranny today and had difficulties with the rear mount. I have that angled mount with the 2 cylinder type rubber mounts. It had an adapter that bolted in front of that for the 4 speed. I removed that but the studs were too far back. Does the bottom plate have to be moved? I have pics but was not able to get them out of my camera tonight. I'll try tomorrow.
Got_All_4
Got_All_4
Hope this helps. I'm sure I've got all the correct pieces to do it it's just a matter of order.
Got_All_4
Got_All_4
Thanks poolboy. I was looking at that this morning and those are the parts I have. However something must not be assembled correctly. The lower bracket may need to come back into the other holes on the tabs welded to the frame.
I think this weekend I'll disassemble them and see if the bracket moves back. You can see the extra hole and the one in front is elongated to accept the angled part of the bracket. That looks like it will pick up the extra length I need.
poolboy
What year is the frame you're using ?
Don't quote me but there may be a difference in the pre 73 frames for mounting the A type OD's
Madflyer
My book shows two different mounts TR 250 /6 to CC85737-- Latter TR 6 CFI on The latter has the round rubber mounts. My TR6 1973 has the latter mounts and the holes are slotted with an OD. If you installed the front motor mounts to block to the rear apox 1/2 inch so front pully has room between front support tube so fan belt passes. you may need the other early mounts. I can not find any measurements to help. Madflyer
I don't see the adapter plates (moss# 59&60) that bolts in between rubber mounts and bottom of trans.
Marv
Reread your post, you have plates, yes the frame mount will need mod. Install mount (with frame mount) on trans and drop down. Thats where you will have to redrill holes.
Bottom plate that mounts to frame will have to be cut and drilled. Hard to do with tran in place. You might get by fabbing another plate to slip under existing one. Not a lot weight or torque there so a thin plate could be used.
Got_All_4
Got_All_4
Just as I suspected I move the bottom plate to the 2 rear holes on the frame mount and every seems o line up perfectly. Now I don't have everything securely bolted in but it looks like that is the set up. When I removed the rubber mounts one of them has perished so I'll have to wait till next week when my local Triumph shop opens up to get 2 new ones.
regularman Still trying to figure this overheating thing out. Spridgets 35
Rob_P Trying to figure out wgich carpet piece goes where MG 7
D Trying to get back working on the 1974 Midget Spridgets 9
B GT6 trying to ID my New Car. GT6 Triumph 6
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
G General TR Trying to reach Frank.... angelfi? Triumph 2
T Trying to identify a steel plate part Austin Healey 2
red57 Trying to identify this gear. Austin Healey 2
K TR2/3/3A Karl's ham handed adventures for your amusement in these trying times. Triumph 8
E Trying to ID some old classic car gauges Restoration & Tools 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
D Trying to understand my cooling system Austin Healey 29
D Lilly second time running... or trying Austin Healey 8
D T-Series Trying to find out an interior dimension MG 7
T Trying to find an accurate tyre pressure gauge Spridgets 24
B MGB Trying to restore emissions controls on 79 MGB MG 0
D TR4/4A trying to identify bolts etc Triumph 5
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
J TR2/3/3A Trying to start engine for the first time! Triumph 11
F Frustration trying to adjust handbrake on Austin Healey BT7 Austin Healey 9
R TR2/3/3A Trying to trace some history on my TR3a Triumph 1
AngliaGT Trying to Rebuild the Brake M/C - Help! Spridgets 5
B New Colorado Red/Signal Red Thread - Trying to get it right Austin Healey 0
tomshobby I am trying to find the past history of my Midget. Spridgets 3
M MGB trying to change rotors - dumb question MG 7
KVH TR4/4A I'm Trying to Tune, Again Triumph 4
S Mk III Sprite cockpit surround - trying to recover Spridgets 9
Answerman Ghost of Lucas is trying to start my Jensen Healey Other British Cars 8
T someone is trying to sell my car Triumph 4
RickB Trying to sell the Sprite Spridgets 27
J Just trying to post pic of cool Jag! Jaguar 0
M Trying to locate William Holden Racing 2
H Trying to help a MG owner, any tips? MG 20
G Trying to reach Robert Triumph 1
H AH 3000 Trying to find the right look Austin Healey 23
M Trying to ID the Right Parts for Clutch Work. Spridgets 1
jlaird Miss Agatha was trying to tell me something Spridgets 4
G My "B" is trying to quit !! MG 7
M Car goes "click" when trying to start - the fix Spridgets 8
bigjones Trying to stay cool Spridgets 0
doughairfield Trying to get my motor started Triumph 8
MCNX_BFF Awakening the Beastie...trying to! Triumph 41
JPSmit trying to understand camshafts Spridgets 22
B TR2/3/3A Williams TR3 Book-Trying to find Triumph 4
OZ_BN1 Trying to identify a part. Other British Cars 21
UmmYeahOk GT6 Is he really trying to sell a GT6? Triumph 22
G Trying to Find T-Shirts Triumph 7
Trevor Jessie Trying out a camera mount... Spridgets 20
M Trying to Find a Family Heirloom Triumph 59
