Paul Johnson
hondo402000 said:Paul
I like the lights but how are they mounted when the hard top is off and the rag top is down??? I am on the trail of a mercedes 560 SL third light
Hondo, in my case the hardtop is on for good, so that issue doesn't come up. What about mounting the light to a thin piece of metal using some sort of epoxy and then bending the metal around 180 degrees so that it can fit at the front edge of the trunk. To hold it still, from inside the trunk you could use several grub screws that would retain it without having to drill hole in the trunk itself.
