Hi Ken, remove the sending unit on top of the gas tank. Mine just needed to be cleaned up, as the wipers on the sides weren't making contact. Also check the small wire that protrudes away from the unit towards the edge, mine was broke. That small wires is grounded to the tank when the screws are tightened. I also added an additional ground strap from one of the mounting screws to the rear bulkhead.
Another thing to check is whether the float attached to the rod isn't filled with gasoline.
Hope this helps, let us know what you find.
