Tricks removing old tenax fasteners? Need 4 tall..
RickB
I had some male tenax fasteners so I put them on my Sprite today and then found they are the shorter ones and I need the longer ones for my top.
My MK1 Midget has the right ones and I was able to remove one without breaking it today.
Any tricks for getting up in the inside of the fender area to hold the nut on the back and remove these?
Or a clue for where I can get these old taller tenax fasteners - I only need 4 of them.
Also right near the back of the door on the rear fender there were two small holes and looking on the Midget there was a little swivel type thing on each side right there - anyone know what that's for?
Platinum
Take a taller one to a good boat supply house and ask 'em for replacements.
Dnno about th' "swivel thing". But there should be a corresponding fastener on the leading edge of the top to fasten to it.
Pythias
If it was on the INSIDE of the cockpit, its for a flap that's on the soft top.
RickB
RickB
I guess I need to go take a picture of the little thing, be back in a minute...
RickB
RickB
Ok, here it is - what is it?
It on the outside just a couple inches down from the top of the fender. It's about 1 inch long (maybe 1.25 inch).
jlaird
Okies, hears the drill. Cut the heads off of those screws. Put them back on with pop rivets, alum ones. I think that is how they came from the factory. In any case my 60 Bugeye in 1962 was that way. Miss Agatha has pop rivets as well.
RickB
RickB
Interesting Jack.
I pulled this off of a MK1 Midget, it was held on (very tightly) with very rusty philips drive screws. So I got stainless steel screws and fastened it with them. I actually put black RTV under the thing so they are sealed to the paint with black RTV and screwed to the body with the stainless screws.
I have no reason to believe they ever came off the Midget until I removed them.
Then again, you never can tell.
The question in my mind is what the heck do they fit? I haven't seen a soft top with a corresponding fitting but I can only imagine that's what they are for.
Gundy
My top and tonneau have these swivel things. They twist and lock
the "critical" edge of the covers. You can see one in this pic.
Is this what you are referring to? Notice it is turned 90 degrees and rests in notch in the cover piece.
chrpark
My 62 Mk II has the same swivel fastner and it's used to lock down the front corner of both the top and tonneau. Fastened to the body with rivets originally.
RickB
RickB
Aha! That's it!!
Thanks guys, now if someone has a close up of the fastener on the top or the tonneau that would be priceless! :wink:
I imagine it's a slot that the swivel part fits into.
Platinum
escutcheon fitting, hole is contoured to fit on the base of the "swivel thingie". Again: check boat supply places.
RickB
RickB
You guys are GREAT!!!
Is there anything you guys / gals and this place can't answer??
Michael Oritt Fresh air 4" hose installation tricks Austin Healey 23
dklawson General Tech Brake Maser Cylinder Pushrod Boot Installation Tricks? Triumph 2
K Tricks or Best Way to Install Front Fenders? Austin Healey 14
J AC air filter tricks and maintenance Other British Cars 0
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
Rob Glasgow Basil's new tricks Austin Healey 6
JodyFKerr Tips & tricks on installing upright air compressor Restoration & Tools 15
tr6nitjulius Shots of the Month [Nov] Tricks & Treats Triumph 2
60Bugeye Sprite Body Work Tips & Tricks For A Novice? Restoration & Tools 24
glemon stupid human tricks mechanical advance Triumph 25
58Custom Any tricks to changing front wheel bearings? Spridgets 7
crya Tricks for attaching door pulls on BJ8?? Austin Healey 8
TR4nut TR2/3/3A Radiator removal TR3A - any tricks? Triumph 12
58Custom Any tricks to replacing fuel pump points? Spridgets 3
58Custom What are the tricks to balancing wire wheels? Spridgets 8
regularman Any windshield installation tricks, tips? Spridgets 17
J New member needing windshield replacing tricks Spridgets 3
Bruce_B Cutting the car for a dual MC setup hints/tricks? Spridgets 23
M Tricks for Alternator Removal 87 XJ6 Series III? Jaguar 8
J Front wheel cylinders [discs] -- any tricks? Triumph 3
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
