Hi Guest!
artpart said:Soup,
The holes you drilled for the taper pin and the "extra" securing bolt...you drilled through both the fork and the cross shaft, right?
Is the taper pin available from ARP?
Chris
artpart said:Soup,
I didn't see the throttle shaft bushings in the fork/shaft kit. Is it TRF kit RFK1249?
D,
Chris, I didn't buy my throttle shaft bushings from either of the big 3. Brosky, Paul, referred me to a website - https://www.McMaster.com. Also, do another search in this forum by entering McMaster in the subject over a period of one month. You'll find a posting by Brosky dated 3-2007-20. This will be very helpful.
Good luck
