jlaird
Lets start a new thread.
I have both transmission setting side by side.
Red on the left green on the right.
Red one has shift fork on the passanger side, green has shift fork on the drivers side??
Red one you can not shift, green one you can.
Both have about the same amount of slot in the shafts but you can tell that the red one is dry inside. I mean really dry and the case is really clean. All the gaskets on the red one seem to be fresh with sealer on them. Wonder what's up with this one. Jolly if you read this maybe you can provide a bit of insight.
Comments folks. What's first you all think, remove the side inspection port? And look for what, broken stuff?
Jack
Jack
