I did take the housing off on the psgr side to replace the "O" ring. That side it not leaking, only the drivers side.I have a 7/64" drill/tap combination and plan to replace the pin with a screw?
The solenoid is on the psgr side. I did remove the solenoid housing to get to the backside recess for the "O" ring. I removed the cover plate today, loosened the bolt on the rod, stuck a drill bit through the lever hole, and set the gap at the solenoid. The lever now moves well.You do not need to remove that pin for the driver's side, which is the solenoid side. For the driver's side you just undo the bolt and remove the arm, and then remove the solenoid/cover plate to get to the seal.
If you use a bolt instead of a pin you will loose motion between the shaft and arm. If you use my recommendation to only use the arm as a starting point that will not be a problem.
LHDAre we working on a LHD or RHD car? that makes a difference on which side you call the drivers side.
The plate that you can unbolt and replace the "O" ring is on the LH side of the OD when you are facing forward in the car. The lever with the tapered pin is on the RH side of the OD.
David
According to the dip stick it is right at the upper mark. It leaks about a 50 cent size spot every two-three days. Where am I going to get a tapered pin? No catalog has one? Explain to me what the lever even does, other then giving you a line up hole for solenoid setup? Is it's placement to just keep the rod in place?A screw will not hold the lever like a tapered pin. You will get movement between the shaft and lever which will increase every time it operates.
As John said the 3/16 locating pin is a starting point but you may have to go a bit further CW to get it to operate.
How much oil is it leaking? Is the OD overfull?
David
See the pic's I sent you. Solenoid on psgr side. LHDOK...I'm lost. On every OD I have seen and owned, the plate with the solenoid is left. I'm afraid you are working on an OD I do not have any experience with.
Taper pins are available from any hardware, industrial supply like McMaster Car, etc. Taper reamers can be found all over Ebay and Amazon.
Sorry, solenoid is right under the driver. Facing forward, you are right , it is on the Lt side.See the pic's I sent you. Solenoid on psgr side. LHD
Sent them on GmailNo, I haven't seen any pictures. Hopefully that will take care of it, though!
is that woodwork and doping fabric ?
respect![]()
You know, David, I swore the o-ring on that side was on the inside too, but then I looked at my build pictures...and I can't tell either way. You have built yours more recently. Do you know whether the passenger side has the o-ring outside or inside the case?So the "O" ring is on the outside?
Glad you got the pin out.
David
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.www.mcmaster.com
McMaster-Carr
Where are these stop levers located?SU carbs use taper pins for the stop levers - possibly the same size?
