While driving slowly I suddenly noticed that I couldn't shift into first or second gear. It was as if the shifter got stuck or was hitting some kind of obstruction. I had a similar issue last year, and thought it went away. But it's back. I can, however, shift into first and second if I slightly lift up on the shifter, somewhat as if I'm going into reverse.
When this last happened I disassembled the shifter and found the anti-rattle button missing. I assumed it had been dislodged and was impeding the shift lever, then dropped out. I no longer think that was the case.
So, my question is whether anyone has an idea here. Do the shift forks get loose or out of line? Would a bad syncro cause the need to pull up on the shifter?
Thanks all.
Thanks all.
