BIBBER
What's the recommended amount of lube for the 62 AH Sprite transmission....I'm having to fill from the stick shift assembly and I fill it up all the way into the upper unit.....only problem is the top portion leaks out fairly quickly and then stops when it lowers to the main gearbox..
Am I overfilling since I'm not usin ghte tunnel plug or just a benefactor of leaking seals?
