Graham H
The welch plug seals the pressure relief and centre shaft lubricating oil drillings so its just an oil distribution centre under the plug. If you take it out be very careful not to drill into the casting under it.I was thinking you may be able to clean it with carb cleaner and put on a good blob of liquid metal held up with tape until it sets , just a temp fix?
Graham
Graham
