trafficator/control head rebuild
Roberte
considering the cost of a new control head assembly for a BJ7 does anyone know where I might get mine rebuilt? My left hand position switch is non functional.
In *most* cases, the unit ceases to function because the works get all gummed up with old oils and greases. The unit can be taken apart and cleaned easily enough, but I should caution you if you decide to do so, as there are several springs, and other little bits that are dying to catapult themselves around your shop.
I've got some pictures of one being disassembled/assembled, but if you absolutely don't want to work on it yourself, I can have a go at it. Unless some of the vital components are damaged beyond use, it'll still be a fair sight less expensive than an entire control unit.
Pictures starting on this album page: https://www.spcarsplus.com/gallery3/index.php/reMKIII/electrical_work
Cleaned and ready to *sparingly* lubricate and assemble:
Patrick67BJ8
How did the engine oil get into it?
Healey Nut
Think of all the years of greasy dirty fingers turning those indicators on and off ,and dirt get into all those liitle cracks n crevisis.. I rebuilt mine . Make sure you have a clean surface and put a light coloured towel or cloth on the surface you are working on . Be ready for some frustration and it will test your patience but it can be done . Take pictures take notes and dont do it if the kids are around , its something you need to have time for .
andrewss
Roberte,
Have a look at this link...
https://www.acmefluid.com.au/larry/trafficator.html
Is the problem mechanical or possibly electrical. Are the horn and right indicator working ? From experience most problems on a trafficator are electrical and relate to one or more of the wires in the trafficator tube being broken and/or twisted.. Please be a little more precise on the problem and i'm sure someone can save you time and money...
R
Roberte
the right turn signals, the running lights and horn work. When checking the flasher for right turn the left and center terminal flashes and the right is lit (with a tester). In the left position the left and right terminal are lit but no flash.
On the flasher relay in left position #1 and 8 are lit, in right position #8 is lit and #7, 1, and 6 flash.
andrewss
Roberto,
Start from the front and work back... Check the bulb in the front left indicator... if its not that check the trafficator cable connections to the main wiring harness located behind and under the the radiator (often attached to the cross arms (X shape) located behind the radiator).... if its not that next step take out the flasher relay on the left hand side of the engine bay hidden slightly by the conduit tube for the fresh air... Check for faulty connections.... if its not that open up the relay and check for corrosion of the tabs inside..... if its not that next step is to follow the guidelines posted in my response and check for twisting in the cable in the trafficator tube.... if its not that check the connection of the wires on the turn signal unit.... check the continuity between the green/yellow wire on the trafficator and the right hand bulb wire connection..... if ALL that fails then its a mechanical problem and follow Randy Forbes advice... Good luck
esussman
I too have a "sticky" trafficator. Signals work when engaged but either side often does not return to center after a turn. Is there an easy fix or do I have to break down the entire assembly?
Thanks,
Eric
5
57_BN4
Eric- that is a fairly common situation where it works fine and cancels the flashing light ok but doesn't return the lever to the centre click position fully. That's what mine does about half of the time.
The two tiny cancelling pegs that stick out are made of some sort of zinc/pot metal (see Randy's third pic) and the angled tips wear down so they can no longer push the lever all the way back to centre. The rotating plate they strike against to cancel (not shown in Randy's pics) also wears and can be bent a very small amount to compensate but that isn't entirely successful as it is almost touching the bakelite parts anyway.
The second problem is that the lever is supported by a bakelite bearing surface on both sides, the top in the big cover section and the bottom in the terminal block section and these wear which allows the lever arm to rub against the cover section. This increases the friction and makes it harder for the little pegs to return it to the centre.
I tried building up the back of a spare cancel peg with zinc filler rod which worked to make it cancel but now the peg sticks out enough to make a click sound each turn of the wheel. Next test is to try building up the worn front angled part of the cancel peg (the back was easier as it is flat) which I'll try this week.
Today I'm going to lathe out the worn centre bearing and make up a bushing out of plastic to reclaim the switch block which will centralise the lever again.
Andy.
[edit]
You can see the centre hole is worn oval in this pic, that is what I'll be reclaiming today
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 4
Lin Another Trafficator/Control Head Question Austin Healey 10
trotti Control head / trafficator questions Austin Healey 14
J TR2/3/3A Correct trafficator control head? Triumph 4
timbn2 "Control Head Assembly" = Trafficator ? Austin Healey 10
Lin Control head "Trafficator" Rebuild Austin Healey 9
Lin Trafficator, control head, turn signal switch/horn Austin Healey 5
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
A Austin A40 trafficator steering wheel Other British Cars 5
F TR2/3/3A Trafficator base Triumph 6
Rob Dodge Trafficator arm issues. Jaguar 2
Michael Oritt Trafficator reinstallation Austin Healey 2
Michael Oritt Trafficator repair and refinish recommendations Austin Healey 6
jfarris TR2/3/3A Access to trafficator Triumph 5
M Trafficator and steering adjustment Austin Healey 4
Johnny AH BJ7 Trafficator Color? Austin Healey 7
Lin Another trafficator issue Austin Healey 8
Michael Oritt Trafficator stopped self-cancelling Austin Healey 19
R Turn signal switch [trafficator] Austin Healey 1
6TTR3A Trade TR3 TRafficator parts Triumph Classifieds 0
M Questions about stator tube and trafficator fixation Austin Healey 31
Griz Trafficator Wiring Question Austin Healey 16
B TR2/3/3A Most likely Trafficator Problem Triumph 5
R TR2/3/3A Turn signal switch [trafficator] Triumph 2
maxwedge5281 refinish trafficator plastic? Austin Healey 20
richberman trafficator part? Austin Healey 2
B Trafficator rebuild Austin Healey 2
M Healey 100-4 Trafficator Lever Needed Austin Healey 5
F TR2/3/3A Horn Button TR3 Trafficator; Bad ground? Triumph 4
Brosky New "Trafficator" now available from Classic Tech Triumph 16
rjc157 trafficator Austin Healey 4
RAC68 Trafficator Head Tube Problem Austin Healey 12
BobbyD TRafficator Signal LED Buzzer Thing Triumph 7
rjc157 trafficator Austin Healey 3
AUSMHLY Trafficator - how to check if it's set correctly Austin Healey 15
martx-5 TR2/3/3A New "Trafficator" for my TR3 Triumph 5
N Healey 100-4 Trafficator Austin Healey 9
Marvin Gruber A/H trafficator part Austin Healey 0
E trafficator Triumph 14
bt7tricarb Trafficator question [adjustable steering] Austin Healey 22
C Trafficator parts Austin Healey 4
H Non adjustable trafficator Austin Healey 2
H Rebuilding a trafficator Austin Healey 4
AUSMHLY trafficator return Austin Healey 21
Johnny Horn switch/trafficator, what again? Austin Healey 5
J Trafficator tests Austin Healey 3
SHG Trafficator is Killing Me! Austin Healey 35
Lin Trafficator Rebuild Latest Austin Healey 0
N BN1 Trafficator Austin Healey 4
bighly Trafficator Pictures and how-to links Austin Healey 2
